Model.hm_wadlinessetparameters#
Model.hm_wadlinessetparameters(side_angle, front_angle, spacing=0, rear_reference_radius=0, reference_resolution=0, upper_bumper_angle=0, lower_bumper_angle=0, corner_angle=0)#
Sets basic parameters for a WAD lines analysis.
Parameters:
  • side_angle (double) – The angle used to determine the side reference line. (Default=45.0)
  • front_angle (double) – The angle used to determine the front reference line. (Default=50.0)
  • spacing (double) – The distance between section cuts used to determine the WAD lines and reference lines. (Default=100.0)
  • rear_reference_radius (double) – The size of the ball rolled along the windshield to find the rear reference line. (Default=100.0)
  • reference_resolution (double) – The spacing between cross-sections used to determine the reference lines. (Default=:python:spacing/2)
  • upper_bumper_angle (double) – The angle used to determine the upper bumper reference line. (Default=20.0)
  • lower_bumper_angle (double) – The angle used to determine the lower bumper reference line. (Default=25.0)
  • corner_angle (double) – The angle used to determine the corner reference lines. (Default=60.0)
Returns:
Example#
Setup and extract WAD lines data#
import hm
import hm.entities as ent
model = hm.Model()
model.hm_wadlinesinit()
model.hm_wadlinessetparameters(
    side_angle=45.0,
    front_angle=50.0,
    spacing=100.0,
    rear_reference_radius=100.0,
    reference_resolution=50.0,
    upper_bumper_angle=20.0,
    lower_bumper_angle=25.0,
    corner_angle=60.0,
model.hm_wadlinessetaxes(
    origin=[0.0, 0.0, 0.0], forwardvec=[1.0, 0.0, 0.0], leftvec=[0.0, 1.0, 0.0]
comps1 = hm.Collection(
    model, ent.Component, "Name=bonnet OR Name=bumper OR Name=fenderL OR Name=fenderR"
comps2 = hm.Collection(model, ent.Component, "Name=windshield OR Name=a-pillars")
model.hm_wadlinessetentities_bycollection(frontEntities=comps1, rearEntities=comps2)
elems = hm.Collection(
    model, ent.Element, hm.Collection(model, ent.Component, name="wipers")
model.hm_wadlinessetwipers(
    wiperEntities=elems, use_for_reference_line=False, use_for_wad_line=True
model.hm_wadlinesgetreferenceline(line_location=0)
model.hm_wadlinesgetreferenceline(line_location=1)
model.hm_wadlinesgetreferenceline(line_location=2)
model.hm_wadlinesgetreferenceline(line_location=3)
model.hm_wadlinesgetreferenceline(line_location=4)
model.hm_wadlinesgetreferenceline(line_location=5)
model.hm_wadlinesgetreferenceline(line_location=6)
model.hm_wadlinesgetreferenceline(line_location=7)
model.hm_wadlinesgetwadline(distance=1000.0)
model.hm_wadlinesgetwadline(distance=1500.0)
model.hm_wadlinesgetwadline(distance=1700.0)
model.hm_wadlinesgetwadline(distance=2100.0)
model.hm_wadlinesgetgridpoints(
    wad_child_min=1000.0,
    wad_child_max=1500.0,
    wad_adult_min=1700.0,
    wad_adult_max=2100.0,
    side_tolerance=50.0,
model.hm_wadlinesend()
