Model.rundesignmethod#
Model.rundesignmethod(entity, appendlogfile=0, columnLabels='', debugInfo=1, loadcaselist='', logfileInfo=1, tableInfo=0, targetentityCollection=Collection(), tableperloadcase=-1)#
Run the design method for a given design point set. The design point set should contain a valid design point and design method.
This outputs a new table entity containing the output of the operation.
Parameters:
  • entity (Entity) – The object describing the designpointset entity.
  • appendlogfile (unsigned int) –
    The flag to append the Stress Tool log file if the method is run on multiple design point sets or elements.
    0 - Off (default)
    1 - On
  • columnLabels (hwString) – The input column label.
  • debugInfo (unsigned int) –
    0 - Do not create a table with input argument data
    1 - Create a table with input argument data (default)
  • loadcaselist (hwString) – The IDs of the method loadcases.
  • logfileInfo (unsigned int) –
    0 - Do not create a stress tool log file
    1 - Create a stress tool log file (default)
  • tableInfo (unsigned int) –
    0 - Do not overwrite output table (default)
    1 - Overwrite output table
  • targetentityCollection (Collection) – The collection containing the elements or designpointsets on which the method is run.
  • tableperloadcase (int) –
    The flag to create Stress Tool method run output table.
    0 - Create single table per run
    1 - Create table per load case for user methods only
    2 - Create a HWASCII result file and import it to the HyperMesh session
Example#
Run the design method for design point set ID 2#
import hm
import hm.entities as ent
model = hm.Model()
model.rundesignmethod(entity=ent.Designpointset(model,2))
Run the design method for design point set ID 2 for elements ID 250 , 251 , and 252#
import hm
model = hm.Model()
    entity=ent.Designpointset(model,2),
    targetentityCollection=hm.Collection(model,ent.Element,[250, 251, 252])
