Model.linedragnodestoformsurface#
Model.linedragnodestoformsurface(sectionnodelist, draglinelist, dragnodelist, refplane_normal, refplane_base, using_default_vector)#
Drags a list of nodes along a trimmed line to create a surface, and optionally, prepares it for immediate use within the automesher. It can also identify a region in the shape of a line-dragged surface for the automesher to use under the mesh without surface option.
Parameters:
  • sectionnodelist (EntityList) – The list of node entities to be dragged.
  • draglinelist (EntityList) – The list of line entities to drag along.
  • dragnodelist (EntityList) – The list of two node entities which lie on the lines in the draglinelist which will be used to trim the line during surface creation.
  • refplane_normal (hwTriple) – The hwTriple object defining the plane normal components. User can also supply a Python list of three doubles.
  • refplane_base (hwTriple) – The hwTriple object defining the base point components of the plane. User can also supply a Python list of three doubles.
  • using_default_vector (int) –
    Flag that defines the type normal vector. Valid options are:
    0 - Use plane normal vector
    1 - Use default normal vector
Example#
Drag nodes with IDs 5 , 9 , and 10 along lines with IDs 2 and 1 , trimmed by nodes with IDs 29 and 30 , and use the given plane , create a surface but no elements#
import hm
import hm.entities as ent
model = hm.Model()
# The model.surfacemode(mode=4) directive tells HyperMesh not to pass the information
#  on to the automesher for element creation.
sectionnode_list = [ent.Node(model, 5), ent.Node(model, 9), ent.Node(model, 10)]
dragline_list = [ent.Line(model, 2), ent.Line(model, 1)]
dragnode_list = [ent.Node(model, 29), ent.Node(model, 30)]
model.linedragnodestoformsurface(
    sectionnodelist=sectionnode_list,
    draglinelist=dragline_list,
    dragnodelist=dragnode_list,
    refplane_normal=[0.0, 1.0, 0.0],
    refplane_base=[0.0, 0.0, 100.0],
    using_default_vector=0,
