Model.CE_FE_AbsorbUsingControl#
Model.CE_FE_AbsorbUsingControl(dim, control, elem_filter, collection=s_defaultCollection, check_for_material=0, combine=0, conn_at_centernode=0, force_proj=0, link_by_card=0, link_by_interface=0, mcf='', org=0, rul='None', shell_connect='none', t_connect='none', thickness_type=0, tol=0.000000, type2_interface=0, weld_cfg_name='', weld_type_num=0, weld_type_name='', area_absorption=0, area_headonly=0, area_in_middle=0, cluster_identify=0, group_links=0, seam_absorption=0, seam_headonly=0, select_special=0, tie_contact=0, attach_link=0, apply_prop=0, link_type=EntityFullType())#
Absorbs certain FE information into connectors using control.
Parameters:
  • dim (int) –
    Defines the type of connector to absorb.
    0 - Spot connectors
    1 - Seam/Area connectors
    4 - Bolt connectors
    5 - Stitch connectors
    6 - Stitch HL connector
    7 - Area Contact connectors
  • control (hwString) – The name of the connectorcontrol entity.
  • elem_filter (hwIntList) – An integer array containing the element IDs to be considered for absorption. If empty, displayed elements will be used.
  • collection (Collection) – Reserved for future development
  • check_for_material (int) –
    0 - Do not check for material for mat100 (hexa)
    1 - Check for material for mat100 (hexa)
  • combine (int) –
    0 - Do not combine in case of equivalent body nodes
    1 - Combine in case of equivalent body nodes
  • conn_at_centernode (int) –
    0 - Do not enable Connector at Centernode for rbe3 (load transfer)
    1 - Enable Connector at Centernode for rbe3 (load transfer)
  • force_proj (int) –
    0 - Do not enable ACM pattern recognition
    1 - Enable ACM pattern recognition
  • link_by_card (int) –
    0 - Do not find link entities by card
    1 - Find link entities by card
  • link_by_interface (int) –
    0 - Do not find link entities by interface
    1 - Find link entities by interface
  • mcf (hwString) – The file name for the main connection file.
  • org (int) –
    0 - Use current component
    1 - Move connectors to FE component
  • rul (hwString) – The re-connect rule. Valid values are “None”, “Use id”, “Use uid”, and “Use name”.
  • shell_connect (hwString) – Valid values are body, head, projs, and none.
  • t_connect (hwString) – Valid values are body, head, projs, and none.
  • thickness_type (int) –
    The spot connector thickness type:
    1 - equival (T1+T2)/2
    3 - shell gap
    5 - const thickness
  • tol (double) – The maximum distance allowed between the connector and each of its links.
  • type2_interface (int) –
    0 - Do not find link entities by interface for type2 (spring)
    1 - Find link entities by interface for type2 (spring)
  • weld_cfg_name (hwString) – The type of FE realization that needs to be converted to connectors.
  • weld_type_num (int) – The selected weld type ID.
  • weld_type_name (hwString) – The selected weld type name.
  • area_absorption (int) –
    0 - Do not absorb as area
    1 - Absorb as area if possible
  • area_headonly (int) –
    0 - Do not only absorb FE with heads as area
    1 - Only absorb FE with heads as area
  • area_in_middle (int) –
    0 - Do not move area to the middle position
    1 - Move area to the middle position
  • cluster_identify (int) –
    0 - Do not absorb single element cluster as area
    1 - Absorb single element cluster as area
  • group_links (int) –
    0 - Do not organize the links into two groups
    1 - Organize the links into two groups
  • seam_absorption (int) –
    0 - Do not absorb as seam
    1 - Absorb as seam if possible
  • seam_headonly (int) –
    0 - Do not only absorb FE with heads as seam
    1 - Only absorb FE with heads as seam
  • select_special (int) –
    0 - Do not enable enhanced approach
    1 - Enable enhanced approach
  • tie_contact (int) –
    0 - Do not enable With tie contact
    1 - Enable With tie contact
  • attach_link (int) –
    0 - Do not use attachments as links
    1 - Use attachments as links
  • apply_prop (int) –
    0 - Do not apply property to connector
    1 - Apply property to connector
  • link_type (EntityFullType) – The type of link to use to absorb. Valid entity types are component, part, property, node, and element.
Example#
Absorb bolt connectors using connectorcontrol “connectorcontrol1”#
import hm
import hm.entities as ent
model = hm.Model()
model.CE_FE_AbsorbUsingControl(
    dim=4,
    control="connectorcontrol1",
    elem_filter=[],
    rul="Use uid",
    tol=20.0,
    attach_link=1,
    org=1,
    link_type=ent.Part,
    apply_prop=1
