Model.createelementsbetweennodes#
Model.createelementsbetweennodes(surf1_collection, surf2_collection, collection, tol, createplot, configval, syst, code, property)#
Creates a spotweld element between two surfaces at the selected nodes with an element type, coordinate system, and property ID.
Parameters:
  • surf1_collection (Collection) – The collection containing the first surface entities.
  • surf2_collection (Collection) – The collection containing the second surface entities.
  • collection (Collection) – The collection containing the node entities.
  • tol (double) – Search tolerance to identify surfaces.
  • createplot (int) – Creates a plot.
  • configval (int) – Element type configuration value.
  • syst (int) –
    Local coordinate system switch.
    0 - Without coordinate system.
    1 - With coordinate system.
  • code (int) –
    Code for one or all surface options.
    0 - All surfaces.
    1 - One surface.
  • property (hwString) – Name of property collector.
Example#
Create spotweld ( spring elements ) between surfaces with IDs 1 and 2 , use the option individual surface and within a tolerance of 0.01 at the nodes with IDs 1 and 2 . Elements are created with the coordinate system and property collector “ name_prop “#
import hm
import hm.entities as ent
model = hm.Model()
surf1 = hm.Collection(model, ent.Surface, [1])
surf2 = hm.Collection(model, ent.Surface, [2])
nodes = hm.Collection(model, ent.Node, [1,2])
model.createelementsbetweennodes(
    surf1_collection=surf1,
    surf2_collection=surf2,
    collection=nodes,
    tol=0.01,
    createplot=1,
    configval=21,
    syst=1,
    code=1,
    property="name_prop",
