Model.show_new_edge_target_by_number#
Model.show_new_edge_target_by_number(face, e1_edge_number, e2_line, is_opposite)#
Displays the target for a selected surface edge number in the new target component.
Parameters:
  • face (Entity) – Entity describing the surface to be offset.
  • e1_edge_number (int) – Number of the surface edge to be offset.
  • e2_line (Entity) – Index of a pilot line.
  • is_opposite (int) –
    0 - Uses e2_line as the target.
    1 - Uses a midline between the e1_edge_number line and e2_line as the target.
Note
Users cannot manually employ this function, because HyperMesh must internally generate the index values (they cannot simply be typed in).
