Model.renumbersolveridlist#
- Model.renumbersolveridlist(entity_list, start_id, incr_val, offset_val, offset_flag, reserved_1, reserved_2, reserved_3)#
Renumbers the solver IDs for entities of entity_type in the order contained in the ordered entity_list.
Works in two ways, depending on the entities selected. If the selected entities have solver IDs, the function renumbers the solver IDs and not the internal IDs. However, if the selected entities do not have solver IDs, the function renumbers the internal IDs (see
Model.renumber()).- Parameters:
entity_list (EntityList) – The ordered list that contains the entities for renumbering.
start_id (unsigned int) – Integer value > 0 specifying the starting value.
incr_val (unsigned int) – Integer value > 0 specifying the renumbering increment.
offset_val (int) – Integer value to use for offsetting. It can be positive or negative, as long as after the renumbering, all entities have a positive ID.
offset_flag (int) –
Flag to specify whether or not to use offsetting.
0 - Use
start_idandincr_valand ignoreoffset_val.1 - Use
offset_valand ignorestart_idandincr_val.reserved_1 (int) – Reserved for future development. Value = 0
reserved_2 (int) – Reserved for future development. Value = 0
reserved_3 (double) – Reserved for future development. Value = 0.0.
Example#
Renumbere the solver IDs of the elements with IDs 1, 2, 3 and 4 start from 1 with an increment of 1#import hm import hm.entities as ent model = hm.Model() model.renumbersolveridlist( entity_list=[ ent.Element(model, 1), ent.Element(model, 2), ent.Element(model, 3), ent.Element(model, 4), ], start_id=1, incr_val=1, offset_val=0, offset_flag=0, reserved_1=0, reserved_2=0, reserved_3=0.0, )
