Model.hm_getsolverkeywordinfoall#
- Model.hm_getsolverkeywordinfoall(format=0)#
Queries all the registered solver keywords. The function always returns a dictionary of keywords against the entity type.
- Parameters:
format (int) – When set to non-zero value, the keywords will be sorted based on priorities identified and registered in the solver browser folder.
- Returns:
hwReturnStatus- Status objectHmQueryResult- Result object containing the output values:keywordinfo (
HmQueryResultList) - Result list object containingHmQueryResultobjects with the following output data:entitytype (str) - The type of the entity for which the keywords are registered.
keywords (list of strings) - The list of keywords registered for the entity type.
Examples#
Querying keywords#import hm import hm.entities as ent model = hm.Model() _, result = model.hm_getsolverkeywordinfoall() for info in result.keywordinfo: print("Entity Type:", info.entitytype) print("Keywords:", info.keywords)
Querying keywords with priority ordering#import hm import hm.entities as ent model = hm.Model() _, result = model.hm_getsolverkeywordinfoall(format=1) for info in result.keywordinfo: print("Entity Type:", info.entitytype) print("Keywords:", info.keywords)
