Model.displaycollectorwithfilter#
Model.displaycollectorwithfilter(entity_type, mode, name, elements, geometry)#
Changes the active state of a collector using the menu filter.
Parameters:
  • entity_type (EntityFullType) – The collector type. Valid types for this function are, Components, Loadcols, Systcols, Vectorcols.
  • mode (hwString) –
    The mode being performed, defined by the following:
    on - All collectors are turned on.
    all - All collectors are turned on.
    off - All collectors are turned off.
    none - All collectors are turned off.
    toggle - All collectors are toggled (visible become invisible and vice-versa).
    reverse - All collectors are toggled (visible become invisible and vice-versa).
  • name (hwString) – The collector name to be used in the above functions. This parameter may be left blank, if mode is set to all, none, or toggle.
  • elements (int) –
    Indicates if elements within components are to be turned on or off.
    0 - No
    1 - Yes
  • geometry (int) –
    Indicates if geometry within components is to be turned on or off.
    0 - No
    1 - Yes
Example#
Turn on the elements and geometry on in component named “ fender “#
import hm
import hm.entities as ent
model = hm.Model()
model.displaycollectorwithfilter(
    entity_type=ent.Component, mode="on", name="fender", elements=1, geometry=1
