Model.CE_ConnectorCreateByAutoseam#
- Model.CE_ConnectorCreateByAutoseam(collection, options)#
Creates line connectors between the input marked components/parts based on the options you supply as the input. All options are needed as the input for this function to work. This function is also supported for history (undo/redo).
- Parameters:
collection (Collection) – The collection containing the entities to create connectors between. Valid entities are parts and components.
options (hwString) –
search_radius=<value> - The distance within which two components/parts should be present to create connectors between them.
pitch=<value> - The distance for the distribution of connector test points.
minimum_connector_length=<value> - The minimum length required to create a connector. Connectors with a length less than the defined value are not created.
exclude_holes_with_radius_less_than=<value> - Holes with a radius less than the defined value are skipped from the connector creation process.
create_internal_seams=<value> - Specifies if the connector is to be created within the same component/part. Valid values are 0 and 1.
Example#
Create the connector between components “componentA” and “componentB” with the following values of the options#import hm import hm.entities as ent model = hm.Model() model.CE_ConnectorCreateByAutoseam( collection=hm.Collection( model, ent.Component, "Name=componentA OR Name=componentB" ), options="search_radius=10.0 pitch=10.0 minimum_connector_length=10.0 exclude_holes_with_radius_less_than=10.0 create_internal_seams=1", )
