Model.dragnodestoformsurface#
Model.dragnodestoformsurface(entitylist, direction_vector, distance, solid_stitch=0)#
Drags a list of nodes to create a surface, and optionally, prepares it for immediate use within the automesher. It can also identify a region in the shape of a dragged surface for the automesher to use under the mesh without surface option.
Parameters:
  • entitylist (EntityList) – The nodes to be dragged.
  • direction_vector (hwTriple) – The direction vector to drag the nodes.
  • distance (double) – The distance to drag the nodes.
  • solid_stitch (int) –
    0 - Created surface will not be stitched to a solid.
    1 - Created surface will be stitched to a solid.
Example#
Drag the nodes with IDs 5, 6, 7, 10, 11 and 12, -100.0 units in the direction of the y-axis, create a surface but no elements#
import hm
import hm.entities as ent
model = hm.Model()
# The model.surfacemode(mode=4) tells HyperMesh not to pass the information on to the automesher for element creation.
nodelist = [ ent.Node(model,id) for id in [5,6,7,10,11,12] ]
model.dragnodestoformsurface(
    entitylist=nodelist,
    direction_vector=[0.0, 1.0, 0.0],
    distance=-100.0,
