Model.hm_getaverageelemsize#
- Model.hm_getaverageelemsize(elems_collection, panel_sensitive_deprecated=1, round_to=0, size_mode=0, limit_range_percent=0.0)#
Returns the average element size for shell elements. This function calculates the average element size using the following formula:
quad elements: \(average\ size\ of\ one\ element\ = \sqrt{1/2 * longest\ diagonal\ * \sum parallel\ altitudes\ }\)
tria elements: \(average\ size\ of\ one\ element\ = \sqrt{area}\)
The total average size is then calculated by summing each average size and dividing by the number of elements considered.
- Parameters:
elems_collection (Collection) – The collection containing the shell element entities to return the average element size.
panel_sensitive_deprecated (int) – Deprecated. Always set to 0.
round_to (int) –
0 - Round up to 3 significant digits (default).
1 - Do not round.
int (size_mode) –
Valid modes are:
0 - Average element size by area
1 - Average element size by edge length
2 - Average minimum element size
3 - Average maximum element size
float (limit_range_percent) –
Valid only for
size_mode1 and 2.For mode 2, min_element_size_limit is output so that limit_range_percent of elements has min_element_size >= min_element_size_limit.
For mode 3, max_element_size_limit is output so that limit_range_percent of elements has max_element_size <= max_element_size_limit.
- Returns:
hwReturnStatus- Status objectHmQueryResult- Result object containing the output values:averageElemSize (double)
Example#
Get the average element size for elements with IDs 1 - 100#import hm import hm.entities as ent model = hm.Model() element_collection = hm.Collection(model, ent.Element, list(range(1, 101))) _, result = model.hm_getaverageelemsize(elems_collection=element_collection) print("Average Element Size:", result.averageElemSize)
