Model.createcirclecenterpoint#
Model.createcirclecenterpoint(point_entity1, point_entity2, point_entity3)#
Creates a point at the center of a circle defined by 3 input points.
Parameters:
  • point_entity1 (Entity) – The object describing the first point entity defining the circle.
  • point_entity2 (Entity) – The object describing the second point entity defining the circle.
  • point_entity3 (Entity) – The object describing the third point entity defining the circle.
Example#
Create a point at the center of the circle defined by points with IDs 100, 200 and 300#
import hm
import hm.entities as ent
model = hm.Model()
model.createcirclecenterpoint(
    point_entity1=ent.Point(model, 100),
    point_entity2=ent.Point(model, 200),
    point_entity3=ent.Point(model, 300),
