Model.morphmaprecalc#
- Model.morphmaprecalc(nlist, nmark, collectionedge, collectionface, mode)#
Recalculates influences and prepare for mapping.
- Parameters:
nlist (EntityList) – The list containing the node entities affected by mapping.
nmark (int) –
0 - Use input list 0
1 - Use input list 1
collectionedge (Collection) – The collection containing the node entities on edge domains where handles will be created.
collectionface (Collection) – The collection containing the node entities on 2D domains where handles will be created.
mode (int) –
0 - Create temporary handles and calculate new influences
1 - Delete temporary handles and restore old influences
Example#
The function makes influence recalculation necessary only once, when entering the panel, rather than each time the user wishes to place a handle or edge.#import hm import hm.entities as ent model = hm.Model() model.morphmaprecalc( nlist=[ent.Node(model, 1), ent.Node(model, 2)], nmark=0, collectionedge=hm.CollectionByInteractiveSelection(model, ent.Node), collectionface=hm.CollectionByInteractiveSelection(model, ent.Node), mode=0, )
Note
This function is called before and after mapping operations in the user control sub-panel to enhance mapping speed.
