Model.hm_projectpointtosegmentwithangle#
- Model.hm_projectpointtosegmentwithangle(px, py, pz, sx1, sy1, sz1, sx2, sy2, sz2, angle)#
Finds the projection point to a specific point on a segment along a specific direction. The result is returned as the point on the straight line that runs from point (
px,py,pz) in the calculated direction, and is the point closest to the straight line that runs through points (sx1,sy1,sz1) and (sx2,sy2,sz2).- Parameters:
px (double) – The x coordinate of the point.
py (double) – The y coordinate of the point.
pz (double) – The z coordinate of the point.
sx1 (double) – The x coordinate of the segment start point.
sy1 (double) – The y coordinate of the segment start point.
sz1 (double) – The z coordinate of the segment start point.
sx2 (double) – The x coordinate of the segment end point.
sy2 (double) – The y coordinate of the segment end point.
sz2 (double) – The z coordinate of the segment end point.
angle (double) – The angle, in degrees, that defines the direction vector in the x-y plane. The
angle=0.0corresponds to the x-direction andangle=90.0corresponds to the y-direction.
- Returns:
hwReturnStatus- Status objectHmQueryResult- Result object containing the output values:point (numpy.ndarray)
Example#
Find the projection of ( 0.0 , 0.0 , 0.0 ) to the segment defined by points ( 1.0 , -1.0 , 0.0 ) and ( 1.0 , 1.0 , 0.0 ) use an angle of 0 ( x - direction )#import hm import hm.entities as ent model = hm.Model() _, result = model.hm_projectpointtosegmentwithangle( px=0.0, py=0.0, pz=0.0, sx1=1.0, sy1=-1.0, sz1=0.0, sx2=1.0, sy2=1.0, sz2=0.0, angle=0.0, ) print("Point: ",result.point)
