Model.setcuttingplanecolor#
- Model.setcuttingplanecolor(axis, mode, color)#
Sets the color of the base of the specified cutting plane.
- Parameters:
axis (int) –
The axis that is normal to the plane. Valid values are:
0 - the plane with x-axis as its normal
1 - the plane with y-axis as its normal
2 - the plane with z-axis as its normal
mode (int) –
Sets the display mode for the specified cutting plane. Valid values are:
0 - solid color
1 - contours
color (int) – The color to use when mode=0. Valid values are 1-64.
Example#
Set the cut plane with y - axis as its normal to use solid color 24#import hm import hm.entities as ent model = hm.Model() model.setcuttingplanecolor(axis=1, mode=0, color=24)
