Model.hm_compareentitiessymmetry#
Model.hm_compareentitiessymmetry(source_entities, target_entities, tolerance, normal_x, normal_y, normal_z, base_x, base_y, base_z, result_type=1, review_results=True)#
Generates comparison results for entities positioned symmetrically about a plane. This must be preceded by a call to Model.hm_compareinit().
These results can then be queried using hm_compareget APIs, or written to a file using hm_comparewrite APIs.
Parameters:
  • source_entities (Collection) – The collection containing the source entities. Valid entities are surfaces or elements.
  • target_entities (Collection) – The collection containing the target entities. Valid entities are surfaces or elements.
  • tolerance (double) – The tolerance value to use for the comparison.
  • normal_x (double) – X-coordinate of symmetry plane normal direction.
  • normal_y (double) – Y-coordinate of symmetry plane normal direction.
  • normal_z (double) – Z-coordinate of symmetry plane normal direction.
  • base_x (double) – X-coordinate of symmetry plane base location.
  • base_y (double) – Y-coordinate of symmetry plane base location.
  • base_z (double) – Z-coordinate of symmetry plane base location.
  • result_type (int) –
    SURFS to SURFS
    SURFS to ELEMS
    ELEMS to SURFS
    ELEMS to ELEMS
    0 - Basic
    Matched (paired)
    Unmatched
    Matched (paired)
    Unmatched
    Matched
    Unmatched
    1 - Full (default)
    Matched (paired)
    Overlapped
    Intersected
    Unmatched
    Matched (paired)
    Overlapped
    Intersected
    Unmatched
    Matched
    Overlapped
    Intersected
    Unmatched
    2 - Detailed
    Matched (paired)
    Overlapped (paired)
    Intersected (paired)
    Unmatched
    Matched (paired)
    Overlapped (paired)
    Unmatched
    Matched
    Overlapped (paired)
    Unmatched
  • review_results (bool) –
    False - Do not automatically show the graphical comparison results after execution.
    True - Automatically show the graphical comparison results after execution (default). This is cleared upon a call to Model.hm_compareend().
Returns:
Example#
Write the detailed comparison results file to “ C:/temp / my_compare.txt “ for the symmetrical comparison of surfuces 1 - 20 and 101 - 120 about the xz - plane with base ( 0.0,50.0,0.0 )#
import hm
import hm.entities as ent
model = hm.Model()
surfs1 = hm.Collection(model, ent.Surface, list(range(1, 21)))
surfs2 = hm.Collection(model, ent.Surface, list(range(101, 121)))
model.hm_compareinit()
model.hm_compareentitiessymmetry(
    source_entities=surfs1,
    target_entities=surfs2,
    tolerance=0.1,
    normal_x=0.0,
    normal_y=1.0,
    normal_z=0.0,
    base_x=0.0,
    base_y=50.0,
    base_z=0.0,
    result_type=2,
    review_results=False,
model.hm_comparewriteresults(
    filename="C:/temp/my_compare.txt", source_component_id=0, target_component_id=0
model.hm_compareend()
