Model.ME_ModuleOccurrencesReparent#
Model.ME_ModuleOccurrencesReparent(child_entity_list, parent_part_entity, options)#
Moves a list of module parts or part assemblies underneath another part assembly in the model hierarchy.
This is only allowed in cases where it does not break sub-assembly instancing.
Parameters:
  • child_entity_list (EntityList) – A list containing the part entities to move.
  • parent_part_entity (Entity) – The object describing the part entity to become the parent.
  • options (hwString) –
    The string of input options.
    matrix_mode=<mode>
    0 - Retain the relative position of the child module (default). This may cause the part to translate if there are matrices stored at different levels in the hierarchy.
    1 - Retain the absolute position of the child module.
Example#
Place the module parts with IDs 100, 101 and 102 under part assembly with ID 8 in the hierarchy. No translation should take place since the parts positions are not change relative to their parents#
import hm
import hm.entities as ent
model = hm.Model()
model.ME_ModuleOccurrencesReparent(
    child_entity_list=[
        ent.Part(model, 100),
        ent.Part(model, 101),
        ent.Part(model, 102),
    parent_part_entity=ent.Part(model, 8),
    options="matrix_mode=1",
