Model.hmplysmoothing#
- Model.hmplysmoothing(collection, num_iters, region_type, tol, split_ply)#
Allows you to create smoothed geometry contour lines and surfaces for ply entities, with various options.
- Parameters:
collection (Collection) – The collection containing the ply entities.
num_iters (int) – The number of smoothing iterations to be run ≥ 0.
region_type (int) –
Flag indicating method used for very local and small ply coverage regions (element patch or hole) detection. Valid values are:
0 - Detect small regions by area ratio
1 - 1etect small regions by element count
tol (double) –
Threshold value to identify local and small ply regions for elimination. The value depends on the
region_type. Particularly:region_type=0(area ratio) - Value oftolindicates the area ratio (calculated by local region area / total design areatol\(\in [{0,1})\)region_type=1(elem count) - Value oftolindicates the number of elements (tol≥ 0, default = 15).split_ply (int) –
0 - Do not create separate ply entities from disconnected ply coverage regions
1 - Create separate ply entities from disconnected ply coverage regions
Example#
Smooth all plies use 20 iterations , eliminate small ply regions with area less than 0.05 of the total design , and finally split disconnected ply coverage regions into separate ply entities#import hm import hm.entities as ent model = hm.Model() ply_collection = hm.Collection(model, ent.Ply) model.hmplysmoothing( collection=ply_collection, num_iters=20, region_type=0, tol=0.05, split_ply=1 )
