Model.correctalloverflowsubmodelentityids#
Model.correctalloverflowsubmodelentityids(submodel_type, id, entity_type, renum_option, poolid)#
Corrects an entity ID range overflow for a submodel.
Parameters:
  • submodel_type (hwString) – Submodel type to correct the ID range overflow for a submodel. Valid values are “includes” and “includefiles”.
  • id (hwString) – The ID of the submodel.
  • entity_type (hwStringList) – The type of entity to correct the overflow for. If set to 0, all entity types in the submodel are considered.
  • renum_option (hwUIntList) –
    1 - Compact and fit (default)
    2 - Move after max
    3 - Move before min
    4 - Insert in gaps
    5 - Offset and fit (not yet supported)
  • poolid (unsigned int) – Reserved for future development
Example#
Correct all overflows in include file 1 with “both” overflow option and using “move after max” renumber option#
import hm
import hm.entities as ent
model = hm.Model()
model.correctalloverflowsubmodelentityids(
    submodel_type="includes", id=1, entity_type="2", renum_option=2, poolid=0
