Model.savefailednodesvectors#
Model.savefailednodesvectors(collection, reduction, scale, segment, magnitude_mode)#
Saves the location, magnitude, and direction of the penetrated areas.
Parameters:
  • collection (Collection) – The collection containing the entities to be modified.
  • reduction (double) – The average thickness reduction.
  • scale (double) – The thickness scale factor.
  • segment (int) – The segment orientation option.
  • magnitude_mode (int) –
    Determines if a magnitude percentage or a uniform size is to be used. Valid values are:
    0 - uniform size
    1 - magnitude percentage
Example#
Save the information of the penetration areas#
import hm
import hm.entities as ent
model = hm.Model()
# Creating a collection that contains all all the penetration areas "E2E"
groups = hm.Collection(model, ent.Group, "name=E2E")
model.savefailednodesvectors(
    collection=groups, reduction=0.0, scale=1.0, segment=1, magnitude_mode=0
