Model.alternatefejointupdate#
- Model.alternatefejointupdate(collection, type, node1, node2, system1, system2, type_flag, node_flag, system1_flag, system2_flag)#
Updates FE joint elements for use with the FE solution sequence.
- Parameters:
collection (Collection) – The collection containing the joint element entities to update.
type (unsigned int) –
The type of FE joint element. Valid values are:
42 - Ball.
system1andsystem2must be specified asNone.43 - Revolute.
system1is mandatory, butsystem2may be specified asNone.44 - Universal.
system1andsystem2must be specified.node1 (Entity) – The first FE joint node entity.
node2 (Entity) – The second FE joint node entity.
system1 (Entity) – The first FE joint system entity.
system2 (Entity) – The second FE joint system entity.
type_flag (int) – Set to 1 to update
type, 0 otherwise.node_flag (int) – Set to 1 to update
node1andnode2, 0 otherwise.system1_flag (int) – Set to 1 to update
system1, 0 otherwise.system2_flag (int) – Set to 1 to update
system2, 0 otherwise.
Example#
Update revolute type FE joint elements with IDs 9 and 10 to be joints of type ball#import hm import hm.entities as ent model = hm.Model() input_col = hm.Collection(model, ent.Element, [9, 10]) model.alternatefejointupdate( collection=input_col, type=42, node1=None, node2=None, system1=None, system2=None, type_flag=1, node_flag=0, system1_flag=0, system2_flag=0, )
