Model.readmeshcontroltemplate#
Model.readmeshcontroltemplate(filename, mode=0)#
Imports a Mesh Control template file. This is an XML formatted file. This contains all of the mesh control information, except for the entity selection. A file coming from can also be read.
Parameters:
  • filename (hwString) – The full name and path of the file to import.
  • mode (int) – Reserved for future development
Example#
Import the file “ C:/temp / meshcontrol.xml “#
import hm
import hm.entities as ent
model = hm.Model()
model.readmeshcontroltemplate(filename="C:/temp/meshcontrol.xml", mode=0)
