Model.hm_exportdummytargetpointstocsv#
Model.hm_exportdummytargetpointstocsv(designPoints, file_path)#
Exports design points in the model with ‘TargetPoint’ configuration to a comma separated values (CSV) file. The following fields will be written in the CSV file:
  • The name of the design point,
  • X/Y/Z,
  • The corresponding test lab measurement data,
  • The allowed negative deviation,
  • The allowed positive deviation,
  • The coordinate value for the measurement node located on the dummy,
  • The signed difference between the CAE position and the test data.
If the specified CSV file already exists, it will be overwritten.
Parameters:
  • designPoints (Collection) – The collection containing the entities of the design points to be exported.
  • file_path (hwString) – The path to the CSV file.
Returns:
Example#
Export design points with IDs 1 , 2 , and 3 to a file named targetpoints.csv located in the C:/temp directory#
import hm
import hm.entities as ent
model = hm.Model()
model.hm_exportdummytargetpointstocsv(
    designPoints=hm.Collection(model, ent.DesignpointTargetPoint, [1, 2, 3]), file_path="C:/temp/targetpoints.csv"
