Model.hm_attributeindexentitytypename#
- Model.hm_attributeindexentitytypename(entity_type, entity_id, attribute_index)#
Returns the entity type string of an indexed entity attribute on an entity.
- Parameters:
entity_type (EntityFullType) – The type of entity to query.
entity_id (unsigned int) – The ID of the entity.
attribute_index (int) – The index of the attribute owned by the queried entity (starting at 1).
- Returns:
hwReturnStatus- Status objectHmQueryResult- Result object containing the output values:entityType (str)
Example#
Get the attribute entity type string of the entity attribute with index 4 on property with ID 1#import hm import hm.entities as ent model = hm.Model() _, result = model.hm_attributeindexentitytypename( entity_type=ent.Property, entity_id=1, attribute_index=4 ) print("entityType", result.entityType)
