Model.hm_ce_gethmholes#
- Model.hm_ce_gethmholes(collection, upbound, lowbound, outerFlag, elementFlag, reserved=0)#
Gets bolt holes information from components.
- Parameters:
collection (Collection) – The collection containing the input component entities.
upbound (double) – Maximum diameter to be considered a bolt hole.
lowbound (double) – Minimum diameter to be considered a bolt hole.
outerFlag (int) – Output the nodes of the outer circle around bolt holes (yes = 1, no = 0).
elementFlag (int) – Output the elements around bolt holes (yes = 1, no = 0).
reserved (int) – Always set to 0.
- Returns:
hwReturnStatus- Status object
Examples#
Get the bolt holes between 0.0 to 15.0 from components with IDs 1 and 2#import hm import hm.entities as ent model = hm.Model() comps = hm.Collection(model, ent.Component, [1, 2]) _, result = model.hm_ce_gethmholes( collection=comps, upbound=15.0, lowbound=0.0, outerFlag=0, elementFlag=0, reserved=0 ) print("Entities: ", result.entities)
