Model.cleanupmodelfile#
- Model.cleanupmodelfile(collection_set, x0, y0, z0, x1, y1, z1, operation)#
Cleans up model specific data after a box trim operation.
- Parameters:
collection_set (CollectionSet) – The set of collections containing possibly multiple type of input entities. The use depends on the
operationargument. Valid entities are Groups, Controlvols and Loads.x0 (double) – Lower bound x-coordinate.
y0 (double) – Lower bound y-coordinate.
z0 (double) – Lower bound z-coordinate.
x1 (double) – Upper bound x-coordinate.
y1 (double) – Upper bound y-coordinate.
z1 (double) – Upper bound z-coordinate.
operation (hwString) –
The operation to perform. Valid values are:
deleteoutsidebox - Deletes all elements, connectors, blocks and groups outside the specified box.
deleteemptyunused - Deletes all empty components, assemblies, sets, contactsurfs, outputblocks, groups, plies and rigidwalls, and all unused materials, properties, sets, beamsects, curves, systems, vectors, laminates, plies and tables.
collection_setandx0throughz1are ignored.preservesolverdata - Preserves all control cards by adding them to
collection_set.x0throughz1are ignored.postclean - Delete the rest of the items not on
Example#
Cleanup model and solver data for LS-DYNA, using a box of 0, 0, 0 - 100,100,100#import hm import hm.entities as ent model = hm.Model() template_type = "lsdyna" # Create element collection outside the box filter = hm.FilterByBox( ent.Element, [0, 0, 0], [100, 100, 100], hm.RELATIVE_LOCATION_OUTSIDE, 0, False, 0.0 ) element_collection = hm.Collection(model, filter) colset = hm.CollectionSet(model) colset.set(element_collection) model.cleanupmodelfile( collection_set=colset, x0=0, y0=0, z0=0, x1=100, y1=100, z1=100, operation="deleteoutsidebox", ) model.cleanupmodelfile( collection_set=colset, x0=0, y0=0, z0=0, x1=0, y1=0, z1=0, operation="deleteemptyunused", ) component_collection = hm.Collection(model, ent.Component) outColSet = hm.CollectionSet(model) model.hm_getincludeisolationentitiesmark( components=component_collection, output_collectionset=outColSet, isolate_special=True, reserved=0, ) if template_type == "lsdyna": model.solverdeckcleanup(solver="LSDYNA", collection_set=outColSet) model.cleanupmodelfile( collection_set=colset, x0=0, y0=0, z0=0, x1=0, y1=0, z1=0, operation="deleteemptyunused", ) model.cleanupmodelfile( collection_set=colset, x0=0, y0=0, z0=0, x1=0, y1=0, z1=0, operation="postclean", )
