Model.tableaddcolumn#
- Model.tableaddcolumn(name, data_type, column_label, string_array)#
Adds a column of data to the right of a table.
- Parameters:
name (hwString) – The name of the table to update.
data_type (hwString) – The data type of the column. See
Model.tablecreate()for valid values.column_label (hwString) – The label of the column.
string_array (hwStringList) – The string array that contains the column data to add. The length of the list should be equal to the number of rows in the table.
Example#
Add a column of type integer and label INTEGER to “ table1 “ which has 7 rows#import hm import hm.entities as ent model = hm.Model() model.tableaddcolumn( name="table1", data_type="int", column_label="INTEGER", string_array=["1", "2", "3", "4", "5","6", "7"], )
