Model.exportuserdefinedshapes#
Model.exportuserdefinedshapes(header, keyword, delimiter1, delimiter1_value, nodeid_width, delimiter2, delimiter2_value, x_coord_width, x_coord_precision, y_coord_width, y_coord_precision, z_coord_width, z_coord_precision, delimiter3, delimiter3_value, outputfile)#
Exports shape design variables, shapes and nodal information in user-defined format for HyperStudy or Templex analysis codes.
Parameters:
  • header (hwString) – Header information for the node block.
  • keyword (hwString) – Keyword for a node.
  • delimiter1 (hwString) –
    The delimiter type between keyword and the node ID. Valid values are:
    Delimiter - Use for delimiters such as slash, comma, etc.
    Whitespace - Use for spaces.
  • delimiter1_value (hwString) –
    If deliminter1 is Delimiter, this is the character to use as the delimiter.
    If delimiter1 is Whitespace, this is the number of spaces.
  • nodeid_width (int) – Width of the node ID field.
  • delimiter2 (hwString) –
    The delimiter type between the node ID and the x-coordinate. Valid values are:
  • delimiter2_value (hwString) –
    If deliminter2 is Delimiter, this is the character to use as the delimiter.
    If delimiter2 is Whitespace, this is the number of spaces.
  • x_coord_width (int) – Field width for output of the x-coordinate.
  • x_coord_precision (int) – Field precision for output of the x-coordinate.
  • y_coord_width (int) – Field width for output of the y-coordinate.
  • y_coord_precision (int) – Field precision for output of the y-coordinate.
  • z_coord_width (int) – Field width for output of the z-coordinate.
  • z_coord_precision (int) – Field precision for output of the z-coordinate.
  • delimiter3 (hwString) –
    The delimiter type between the x-y and y-z coordinates. Valid values are:
  • delimiter3_value (hwString) –
    If deliminter3 is Delimiter, this is the character to use as the delimiter.
    If delimiter3 is Whitespace, this is the number of spaces.
  • outputfile (hwString) – Name of the output file.
Example#
Output nodal coordinates in the following format to the shape.dat file :#
COORDINATES
NODE  /     8844, 5.0000000e+001  6.0000000e+001  5.0000000e+001
import hm
import hm.entities as ent
model = hm.Model()
model.exportuserdefinedshapes(
    header="COORDINATES",
    keyword="NODE",
    delimiter1="Delimiter",
    delimiter1_value="/",
    nodeid_width=9,
    delimiter2="Delimiter",
    delimiter2_value=",",
    x_coord_width=15,
    x_coord_precision=7,
    y_coord_width=15,
    y_coord_precision=7,
    z_coord_width=15,
    z_coord_precision=7,
    delimiter3="Whitespace",
    delimiter3_value="1",
    outputfile="shape.dat",
