Model.morphconstraintupdateedge#
- Model.morphconstraintupdateedge(mcon, dptr1, dptr2, end, type, vec, color)#
Updates a tangency type constraint either between two edge domains or 2D domains or at the end of one edge domain. When
type="main",dptr1is the main anddptr2is the secondary. Whentype="secondary",dptr2is the main anddptr1is the secondary. Whentype="attached",dptr1followsdptr2.- Parameters:
mcon (Entity) – The entity morph constraint to update.
dptr1 (Entity) – The line entity of the edge or 2D domain.
dptr2 (Entity) – The line entity of the edge or 2D domain.
end (Entity) – The node entity at fixed end (for fixed type).
type (int) –
1 - Fixed (edge domains only)
2 - Main (edge domains only)
3 - Secondary (edge domains only)
4 - Continuous
5 - Attached (edge domains only)
vec (hwTriple) – The hwTriple object defining the vector components. User can also supply a Python list of three doubles.
color (int) – The color of the constraint. Valid values are 1 through 64.
Examples#
Update a continuous tangency constraint with ID 5 between domains with IDs 12 and 14#import hm import hm.entities as ent model = hm.Model() model.morphconstraintupdateedge( mcon=ent.Morphconstraint(model, 5), dptr1=ent.Line(model, 12), dptr2=ent.Line(model, 14), end=ent.Node(model, 1), type=4, vec=[1.0, 0.0, 0.0], color=44, )
Update a secondary tangency constraint with ID 12 where domain with ID 14 is forced tangent to domain with ID 12#import hm import hm.entities as ent model = hm.Model() model.morphconstraintupdateedge( mcon=ent.Morphconstraint(model, 12), dptr1=ent.Line(model, 12), dptr2=ent.Line(model, 14), end=ent.Node(model, 1), type=2, vec=[1.0, 0.0, 0.0], color=44, )
