Model.loaddefaultattributevaluesfromxml#
Model.loaddefaultattributevaluesfromxml(xmlfilename)#
Loads the entity’s default setting values, mandatory values, show/hide values, and so on, that are defined in the specified XML file. If the file name is not specified, it unloads the previously loaded default settings.
Parameters:
xmlfilename (hwString) – The XML file path containing the entity default settings.
Example#
Load the default values specified in the “ EntityDefaults.xml “ file#
import hm
import hm.entities as ent
model = hm.Model()
model.loaddefaultattributevaluesfromxml(
    xmlfilename="D:/settingsfile/EntityDefaults.xml"
