Model.morphhandlecreatexyz#
- Model.morphhandlecreatexyz(dcollectionhandle, domain, name, xx, yy, zz, sys)#
Creates handle at x,y,z, location for the given system.
- Parameters:
dcollectionhandle (Collection) – The collection containing the handle entities.
domain (Entity) – The entity domain. This argument can also be set to None.
name (hwString) – Name of handle(s) to be created.
xx (double) – X coordinate of handle to be created.
yy (double) – Y coordinate of handle to be created.
zz (double) – Z coordinate of handle to be created.
sys (int) – The ID of the entity system to create handle in (default = global).
Example#
Create a handle on the specified domain at the x, y, and z coordinates for the given system with dependencies on the handles on the collection#import hm import hm.entities as ent model = hm.Model() model.morphhandlecreatexyz( dcollectionhandle=None, domain=ent.Domain(model, 1), name="bob", xx=1.0, yy=2.0, zz=3.0, sys=3, )
Note
The name does not need to be unique since this function will create a unique name for each new handle by adding numbers after the name.
