Model.hm_compareinit#
Model.hm_compareinit()#
Initializes the comparison module. This must precede any calls to other hm_compare APIs, and must be followed by a call to Model.hm_compareend().
Any database changes made while inside of the compare module will invalidate and delete any comparison results.
Returns:
Example#
Write the detailed comparison results file to “ C:/temp / my_compare.txt “ for the same side comparison of surfuces with IDs 1 - 20 and 101 - 120#
import hm
import hm.entities as ent
model = hm.Model()
surfs1 = hm.Collection(model, ent.Surface, list(range(1, 21)))
surfs2 = hm.Collection(model, ent.Surface, list(range(101, 121)))
model.hm_compareinit()
model.hm_compareentitiessameside(
    source_entities=surfs1,
    target_entities=surfs2,
    tolerance=0.1,
    result_type=2,
    review_results=False,
model.hm_comparewriteresults(
    filename="C:/temp/my_compare.txt", source_component_id=0, target_component_id=0
model.hm_compareend()
