Model.cuttingplanereverse#
Model.cuttingplanereverse(id)#
Reverses a cutting plane display orientation.
Parameters:
axis (int) –
The axis that is normal to the plane. Valid values are:
0 - The plane with x-axis as its normal.
1 - The plane with y-axis as its normal.
2 - The plane with z-axis as its normal.
Example#
Reverse the cut plane with y - axis as its normal#
import hm
import hm.entities as ent
model = hm.Model()
model.cuttingplanereverse(axis=1)
