Model.CE_DetailSetTriple#
Model.CE_DetailSetTriple(connector_id, detail_name, triple_value1, triple_value2, triple_value3, reserved, force_storage)#
Sets a triple connector detail for a single connector.
Parameters:
  • connector_id (unsigned int) – The ID of connector to update.
  • detail_name (hwString) –
    The name of the standard triple detail, or user-defined triple detail, to update. Standard triple details include:
    • ce_dircords
    The coordinates of the direction node.
    • ce_ijk
    The vector definition used for realization.
  • triple_value1 (double) – The first triple value to update for the detail.
  • triple_value2 (double) – The second triple value to update for the detail.
  • triple_value3 (double) – The third triple value to update for the detail.
  • reserved (unsigned int) – Reserved for future development. Must be set to 0.
  • force_storage (unsigned int) –
    0 - Do not store user-defined detail.
    1 - Store user-defined detail.
Example#
Set the projection vector to (0.0, 1.0, 0.0) for connector with ID 1#
import hm
import hm.entities as ent
model = hm.Model()
model.CE_DetailSetTriple(
    connector_id=1,
    detail_name="ce_ijk",
    triple_value1=0.0,
    triple_value2=1.0,
    triple_value3=0.0,
    reserved=0,
    force_storage=0,
