Model.CE_ReviewConnectorsReverse#
- Model.CE_ReviewConnectorsReverse(entity_type, output_collection_set, first_connector_entity=0, linked_entity=0, realization_connector=0, second_connector_entity=0)#
Performs reverse connector review operation.
- Parameters:
entity_type (EntityFullType) – The entity type on which the reverse review operation will be performed. Valid values are connectors and attachments.
output_collection_set (CollectionSet) – The set of collections containing possibly multiple type of entities onto which the reviewed entities are placed.
first_connector_entity (unsigned int) – Defines if the first connector entity needs to be considered for reverse review operation. Valid values are 1 or 0.
linked_entity (unsigned int) – Defines if the linked entites need to be considered for reverse review operation. Valid values are 1 or 0.
realization_connector (unsigned int) – Defines if the realized/solver entites need to be considered for reverse review operation. Valid values are 1 or 0.
second_connector_entity (unsigned int) – Defines if the second connector entity needs to be considered for reverse review operation. Valid values are 1 or 0.
Example#
Perform reverse review operation on connectors#import hm import hm.entities as ent model = hm.Model() OutputCollectionSet = hm.CollectionSet(model) model.CE_ReviewConnectorsReverse( entity_type=ent.Connector, output_collection_set=OutputCollectionSet, first_connector_entity=1, linked_entity=0, second_connector_entity=0, )
