Model.voxel_lattice_hex_mesh_remove_entities#
- Model.voxel_lattice_hex_mesh_remove_entities(collection, mode)#
Removes entities from the voxel domain. Voxel gridding is removed along the intersection profile of the entities. This must be preceded by a call to
Model.voxel_lattice_hex_mesh_init()and must be followed by a call toModel.voxel_lattice_hex_mesh_create().- Parameters:
collection (Collection) – The collection containing the entities to be removed. Valid entities are component, element, surface, solid and line entities.
mode (int) –
1 - Remove voxelization only for the input entity profile.
2 - Remove voxelization only for voids/volumes of the input entity profile.
3 - Remove voxelization for both the input entity and voids/volumes.
Example#
Create voxels of size 10.0 to include components with IDs 100 - 110 and exclude components with IDs 200 - 203#import hm import hm.entities as ent model = hm.Model() # Creating a collection that contains the components to be included filter_in_components = hm.FilterByEnumeration(ent.Component, list(range(100, 111))) in_component_collection = hm.Collection(model, filter_in_components) # Creating a collection that contains the components to be excluded filter_out_components = hm.FilterByEnumeration(ent.Component, list(range(200, 204))) out_component_collection = hm.Collection(model, filter_out_components) model.voxel_lattice_hex_mesh_init(voxel_size=10.0) model.voxel_lattice_hex_mesh_fill_voids(mode=0) model.voxel_lattice_hex_mesh_add_entities(collection=in_component_collection, mode=1) model.voxel_lattice_hex_mesh_remove_entities( collection=out_component_collection, mode=1 ) model.voxel_lattice_hex_mesh_create() model.voxel_lattice_hex_mesh_end()
