Model.barelementupdatelocal#
- Model.barelementupdatelocal(collection, update_vector, vector, update_pins, pin_flags_a, pin_flags_b, update_property, property_name)#
Updates the vector (local system), pin flags and property for multiple bar and/or bar3 elements.
- Parameters:
collection (Collection) – The collection containing the bar and/or bar3 element entities to update.
update_vector (int) – If non-zero,
vectoris used to update the local y-axis.vector (hwTriple) – The hwTriple object defining the vector components. User can also supply a Python list of three doubles.
update_pins (int) – If non-zero,
pin_flags_aandpin_flags_bare used to update the pin flags.pin_flags_a (hwBoolList) – The pin flags at end a. A pin flag of None passes forces in all degrees of freedom.
pin_flags_b (hwBoolList) – The pin flags at end b. A pin flag of None passes force in all degrees of freedom.
update_property (int) – If non-zero,
property_nameis used to update the property.property_name (hwString) – The name of the property collector assigned to the bar.
Example#
Update bar elements with IDs 10 and 12 with local y-axis defined by (1.0, 0.0, 0.0) using the local system at end a and property “crossmem”#import hm import hm.entities as ent model = hm.Model() elems = hm.Collection(model, ent.Element, [10, 12]) model.barelementupdatelocal( collection=elems, update_vector=1, vector=(1.0, 0.0, 0.0), update_pins=0, pin_flags_a=None, pin_flags_b=None, update_property=1, property_name="crossmem" )
