Model.marksmoothelements#
- Model.marksmoothelements(tosmoothcollection, toanchorcollection, smoothmethod, iterations)#
Applies a smoothing algorithm to a collection of elements for a given number of iterations. Optionally, one or more nodes may be specified as being anchored in place and not movable.
- Parameters:
tosmoothcollection (Collection) – The collection containing the element entities to be smoothed.
toanchorcollection (Collection) – The collection containing the node entities on those elements that are not adjustable.
smoothmethod (int) –
The smoothing method to use.
1 - autodecide
2 - size corrected
3 - shape corrected
4 - angle corrected
iterations (int) – The number of times to apply the smoothing operator.
Example#
Smooth elements with IDs 100 through 110 twelve times with no nodes fixed#import hm import hm.entities as ent model = hm.Model() Elements = hm.Collection(model, ent.Element, list(range(100, 111))) Nodes = hm.Collection(model, ent.Node, [2]) model.marksmoothelements( tosmoothcollection=Elements, toanchorcollection=Nodes, smoothmethod=1, iterations=12 )
