Model.hm_getmodelcheckcheckstatus#
- Model.hm_getmodelcheckcheckstatus(check_display_name)#
Returns the status for a given check.
- Parameters:
check_display_name (hwString) – The GUI display name of the check. This is case sensitive.
- Returns:
hwReturnStatus- Status objectHmQueryResult- Result object containing the output values:status (int)
0 - Check is not run
1 - Check is run and there are failed entities
2 - Check is run but there are no failed entities
3 - Relevant entities to run the check are not present in the model
Example#
Get the status for the “ Unused materials “ check#import hm import hm.entities as ent model = hm.Model() _, result = model.hm_getmodelcheckcheckstatus( check_display_name="Unused materials" ) print("status:", result.status)
