Model.hm_intersectlineline#
Model.hm_intersectlineline(segment1Start, segment1End, segment2Start, segment2End)#
Returns the intersection point of two lines consisting of the four 3D points, which are the start and end points of two segments.
Parameters:
  • segment1Start (hwTriple) – Start point of the first segment.
  • segment1End (hwTriple) – End point of the first segment.
  • segment2Start (hwTriple) – Start point of the second segment.
  • segment2End (hwTriple) – End point of the second segment.
Returns:
  • hwReturnStatus - Status object
  • HmQueryResult - Result object containing the output values:
    • intersectionPointCoordinates (numpy.ndarray)
Example#
Return values x , y , z from given segment points#
import hm
import hm.entities as ent
model = hm.Model()
_, result = model.hm_intersectlineline(
    segment1Start=[0.0, 0.0, 0.0],
    segment1End=[2.0, 0.0, 0.0],
    segment2Start=[-1.0, 0.0, 0.0],
    segment2End=[1.0, 0.0, 0.0]
print("intersectionPointCoordinates", result.intersectionPointCoordinates)
