Model.morphapplyfesolver#
- Model.morphapplyfesolver()#
This function will invoke a finite element solver, specified by the
fesolverof the functionModel.morphupdateparameter(), and solve for the internal perturbations for all domains which have fewer elements than that specified by thefesolverlimitof the functionModel.morphupdateparameter()using enforced displacements applied at the domain handles, edges, and/or faces. The function will either use the properties and materials specified for the mesh or generate properties and materials automatically depending on thefeuserof the functionModel.morphupdateparameter().Has no arguments but uses several parameters when it is executed which are described below. These parameters can be updated using the
Model.morphupdateparameter()function.More specifcally the arguments of this function to update are:
fesolver
0 - Linear solver (OptiStruct)
1 - Nonlinear solver (Radioss)
fesolverlimit
Domains containing less than this number of elements will be updated.
feuser
0 - Use automatically generated properties and materials
1 - Use properties and materials currently for the mesh
Example#
Invoke the FE solver#import hm import hm.entities as ent model = hm.Model() ''' FE Solver paramaters were set up before the following line... ''' model.morphapplyfesolver()
