Model.hm_getedgeloops#
- Model.hm_getedgeloops(collection, looptype=255, surf_collection=Collection(), featureangle=0.0, restricttoinput=0)#
Returns surface and element free and non-manifold edge loop entities. The return is a list of loops. Each loop is an ordered list of either surface edge or element node entities that define each loop. The first value in each loop list is the loop type. The remaining values are the ordered node/surface edge entities defining the loop. If the loop is closed, the first and last entity object are the same.
- Parameters:
collection (Collection) – The collection containing the entities. Currently supported for surfaces and elements.
looptype (int) –
The type of loop types to find.
Bit values are used and the value is calculated as (1*Bit0 + 2*Bit1 + 4*Bit2 + 8*Bit3 + 16*Bit4 + 32*Bit5 + 64*Bit6 + 128*Bit7). If not specified, all loop types are returned. Valid Bit options are:
Bit0
Consider open free edge loops. Valid values are:
0 - Do not consider open free edge loops
1 - Consider open free edge loops
Bit1
Consider closed free edge loops. Valid values are:
0 - Do not consider closed free edge loops
1 - Consider closed free edge loops
Bit2
Consider open t-connections. Valid values are:
0 - Do not consider open t-connections
1 - Consider open t-connections
Bit3
Consider closed t-connections. Valid values are:
0 - Do not consider closed t-connections
1 - Consider closed t-connections
Bit4
Consider open x-connections. Valid values are:
0 - Do not consider open x-connections
1 - Consider open x-connections
Bit5
Consider closed x-connections. Valid values are:
0 - Do not consider closed x-connections
1 - Consider closed x-connections
Bit6
Consider open feature edge loops. Valid values are:
0 - Do not consider open feature edge loops
1 - Consider open feature edge loops
Bit7
Consider closed feature edge loops. Valid values are:
0 - Do not consider closed feature edge loops
1 - Consider closed feature edge loops
Show Bit value calculator
Radio Button Table Option Name Value Consider open free edge loops (Bit0) Consider closed free edge loops (Bit1) Consider open t-connections (Bit2) Consider closed t-connections (Bit3) Consider open x-connections (Bit4) Consider closed x-connections (Bit5) Consider open feature edge loops (Bit6) Consider closed feature edge loops (Bit7) Calculated argument value: 0 surf_collection (Collection) – The collection containing the entities. Currently supported for surfaces and elements.
featureangle (double) – This is relevant to finding feature edges only. When an edge is shared by two surfaces, and the average angle along the edge between these two surfaces is greater than
featureangle, then it is considered a feature edge. The angle is measured in degrees. The default value is the model’s default feature angle preference.restricttoinput (int) –
0 - Loops are completed naturally for the whole model, which might result in including edges that are not in the input specified by
surf_collection.1 - The loop output is restricted to the set of edges that are given by the input only.
- Returns:
hwReturnStatus- Status objectHmQueryResultList- Result list object containingHmQueryResultobjects with the following output data:loopType (int) - The type of loop.
0 - Undefined loop
1 - Open free edge loop
2 - Closed free edge loop
4 - Open t-connection
8 - Closed t-connection
16 - Open x-connection
32 - Closed x-connection
64 - Open feature edge loop
128 - Closed feature edge loop
loopEntities (EntityList) - The list of entity objects representing the loop. For
collectioncontaining surfaces, the entities are surface edges. Forcollectioncontaining elements, the entities are element nodes.
Example#
Find all edge loops on displayed elements#import hm import hm.entities as ent model = hm.Model() elements = hm.CollectionByDisplayed(model,ent.Element) _, resultlist = model.hm_getedgeloops(collection=elements, looptype=255) for result in resultlist: print("Loop Type:", result.loopType) print("Number of Loop Entities:", len(result.loopEntities))
