Model.morphmapsections#
- Model.morphmapsections(collectionelem, collectionnode, collectionline, collectionfix, plane_normal, plane_base, rotate, blend, axis, sym, con)#
Maps elements on collection to section lines.
- Parameters:
collectionelem (Collection) – The collection containing the element entities to map.
collectionnode (Collection) – The collection containing the follower node entities.
collectionline (Collection) – The collection containing the section line entities.
collectionfix (Collection) – The collection containing the fixed node entities.
plane_normal (hwTriple) – The hwTriple object defining the plane normal components. User can also supply a Python list of three doubles.
plane_base (hwTriple) – The hwTriple object defining the base point components of the plane. User can also supply a Python list of three doubles.
rotate (int) –
0 - L point to point mapping between lines
1 - Rotate nodes along with curvature difference between lines
blend (int) –
0 - Do no blend unselected nodes
1 - Blend nodes between mapped and fixed nodes
axis (int) –
0 - Apply mapping in x, y, z coordinates
1 - Apply mapping about axis defined by plane
sym (int) – 0 - Do not use symmetry (only option)
con (int) –
0 - Do not use constraints
1 - Use constraints
Example#
Map the selected selected elements to an interpolated cross section given the section lines optionally follow the curvature differences ( rotate ) or mapping about an axis ( axis and plane ) . interpolate a number ofModel.morphmapdifference()calls between line pairs. The initial lines are found by intersect a plane normal to each section line with the selected elements. Thus, the selected elements should match up closely with the selected lines.#import hm import hm.entities as ent model = hm.Model() model.morphmapsections( collectionelem=hm.CollectionByInteractiveSelection(model, ent.Element), collectionnode=hm.CollectionByInteractiveSelection(model, ent.Node), collectionline=hm.CollectionByInteractiveSelection(model, ent.Line), collectionfix=hm.CollectionByInteractiveSelection(model, ent.Node), plane_normal=[1.0, 0.0, 0.0], plane_normal_base=[1.0, 0.0, 0.0], rotate=0, blend=0, axis=0, sym=0, con=1, )
Note
If
blend=1, no fixed nodes have been selected, and no mapped nodes are a part of any domain, this function will automatically assign all non-mapped nodes as fixed nodes.
