Model.hm_clustersurfaces#
- Model.hm_clustersurfaces(collection, featAngle)#
Forms clusters of surfaces from the given input collection of surfaces, grouping surfaces that are adjacent with angle less than the specified threshold. The surfaces are grouped even across t-connection edges. The function returns a list of lists of surface IDs.
- Parameters:
collection (Collection) – The collection containing the surface entities to cluster.
featAngle (double) – The angle threshold (in degrees) used for grouping two surfaces together. If the angle between two surfaces at common edge is less than this value, they are grouped together.
- Returns:
hwReturnStatus- Status objectHmQueryResultList- Result list object containingHmQueryResultobjects with the following output data:clusterSurfs (EntityList) - List of surfaces - Entity Type:
Surface
Example#
Group all the surfaces that are connected at an angle less than 20 degrees at the common edge#import hm import hm.entities as ent model = hm.Model() surface_collection = hm.Collection(model, ent.Surface) _, resultlist = model.hm_clustersurfaces(collection=surface_collection, featAngle=20.0) for result in resultlist: print("Surfaces:", [s.id for s in result.clusterSurfs])
