Model.hm_compareentities#
- Model.hm_compareentities(source_surfaces, target_surfaces, tolerance, result_type=1, review_results=True)#
Generates comparison results for entities positioned at any location. A maximum of one match is found for each source entity. This must be preceded by a call to
Model.hm_compareinit().These results can then be queried using hm_compareget APIs, or written to a file using hm_comparewrite APIs.
- Parameters:
source_surfaces (Collection) – The collection containing the source entities. Valid entities are surfaces or elements.
target_surfaces (Collection) – The collection containing the target entities. Valid entities are surfaces or elements.
tolerance (double) – The tolerance value to use for the comparison.
result_type (int) –
SURFS to SURFS
0 - Basic
Matched (paired)
Unmatched
1 - Full (default)
Matched (paired)
Overlapped
Intersected
Unmatched
2 - Detailed
Matched (paired)
Overlapped (paired)
Intersected (paired)
Unmatched
review_results (bool) –
False - Do not automatically show the graphical comparison results after execution.
True - Automatically show the graphical comparison results after execution (default). This is cleared upon a call to
Model.hm_compareend().
- Returns:
hwReturnStatus- Status object
Example#
Write the detailed comparison results file to “ C:/temp / my_compare.txt “ for the same side comparison of surfs with IDs 1 - 20 and 101 - 120#import hm import hm.entities as ent model = hm.Model() surfs1 = hm.Collection(model, ent.Surface, list(range(1, 21))) surfs2 = hm.Collection(model, ent.Surface, list(range(101, 121))) model.hm_compareinit() model.hm_compareentitiessameside( source_entities=surfs1, target_entities=surfs2, tolerance=0.1, result_type=2, review_results=False, ) model.hm_comparewriteresults( filename="C:/temp/my_compare.txt", source_component_id=0, target_component_id=0 ) model.hm_compareend()
