Model.show_new_target#
Model.show_new_target(face, offsetpoint_x, offsetpoint_y, offsetpoint_z, target_x, target_y, target_z, code)#
Draws a segment in the new target component. This segment connects the point to offset with the target point.
Parameters:
  • face (Entity) – Entity describing the surface to be offset.
  • offsetpoint_x (double) – The x-coordinate of the point to be offset.
  • offsetpoint_y (double) – The y-coordinate of the point to be offset.
  • offsetpoint_z (double) – The z-coordinate of the point to be offset.
  • target_x (double) – The x-coordinate of the pilot point.
  • target_y (double) – The y-coordinate of the pilot point.
  • target_z (double) – The z-coordinate of the pilot point.
  • code (int) –
    -1 - The function combines the targets that existed at the vertex; the pilot point is ignored.
    -5 - As for option code=-1, but also displays the targets being combined component.
    0 - The target point is a midpoint between the offset point and the pilot point.
    1 - The target point is the pilot point.
    2 - The target point is a midpoint between the offset point and the pilot point. If the offset point is at a vertex of the surface to offset, the target is combined with any existing targets for that vertex and displays the combined target in the new target component.
    3 - The target point is the pilot point. If the offset point is at a vertex of the surface to offset, the target is combined with any existing targets for that vertex and displays the combined target in the new target component.
    4 - Behaves exactly as option 2, but also displays the targets being combined and the target planes in the targets being combined component.
    5 - Behaves exactly as option 3, but also displays the targets being combined and the target planes in the targets being combined component.
Note
Users cannot manually employ this function, because HyperMesh must internally generate the index values (they cannot simply be typed in).
