Model.hm_findnarrowsurfaces#
- Model.hm_findnarrowsurfaces(collection, width_threshold, output_surfs_flag=0, sharp_angle_threshold=10, reserved=0)#
Returns a list of narrow surfaces, including large surfaces with narrow tails or local narrow neck regions. If
output_surfs_flagis set to 1, the result object will contain a list of surface entities and a list of flags indicating the type of narrow surface.Each flag represents a bit-wise flags mask:
1 - Sliver surface
2 - Surface containing a narrow neck region
4 - Surface containing a narrow tail region
8 - Surface containing both a narrow neck and a narrow tail region
- Parameters:
collection (Collection) – The collection containing the entities to query. Valid entities are surfaces, solids, and components.
width_threshold (double) – Positive value defining the maximal width of a narrow surface, or maximal gap for a surface narrow tail or neck region.
output_surfs_flag (int) –
Parameter defining the output mode.
0 - Output contains only list of surface entities (default)
1 - Output contains an additional list of flags for narrow surfaces
sharp_angle_threshold (double) – An angle, in degrees, that represents a corner angle above which the area nearby a surface corner is not considered as a narrow region. (default 10.0)
reserved (int) – Reserved for future use. Must be set to 0.
- Returns:
hwReturnStatus- Status objectHmQueryResult- Result object containing the output values:surfaces (list) - List of surface entities that are considered narrow surfaces.
flags (list) - List of flags for each narrow surface. The output is available if
output_surfs_flagis set to 1. Each flag is a bit-wise mask indicating the type of narrow surface.
Examples#
Find narrow surfaces with width below 0.2 for component “main_body”#import hm import hm.entities as ent model = hm.Model() comp_col = hm.Collection(model, ent.Component, "name=main_body") _, result = model.hm_findnarrowsurfaces(collection=comp_col, width_threshold=0.2) for surf in result.surfaces: print("Surface ID: ",surf.id)
Find narrow surfaces with width below 0.2 for component “main_body” and additionally get list of flags for each narrow surface#import hm import hm.entities as ent model = hm.Model() comp_col = hm.Collection(model, ent.Component, "name=main_body") _, result = model.hm_findnarrowsurfaces( collection=comp_col, width_threshold=0.2, output_surfs_flag=1 ) for surf, flag in zip(result.surfaces, result.flags): print("Surface ID: ",surf.id) print("Flag: ", flag)
