Model.beamsectioncreatestandardsolver#
Model.beamsectioncreatestandardsolver(type, solver, type_name, orient)#
Creates a standard solver-specific section. For a list of values that are supported by each solver, see the topics in the See Also section.
Parameters:
  • type (int) – Integer indicating the type of section to create. Each solver has a number of available sections.
  • solver (int) –
    Integer indicating the solver the section is being created for. Valid values are:
    0 - HyperBeam
    1 - OptiStruct/Nastran
    2 - Abaqus
    8 - ANSYS
    9 - LS-DYNA
    21 - Permas
  • type_name (hwString) – Name indicating the type of section to create. Each type can have multiple available section names.
  • orient (int) –
    Flag indicating the orientation of the section:
    0 - 0 degrees
    1 - 90 degrees
    2 - 180 degrees
    3 - 270 degrees
Examples#
Create a standard HyperBeam T-section having a 0 degree orientation#
import hm
import hm.entities as ent
model = hm.Model()
model.beamsectioncreatestandardsolver(
    type=1,
    solver=12,
    type_name="I",
    orient=0
Create a standard OptiStruct T-section having a 0 degree orientation#
import hm
model = hm.Model()
    type=15,
    solver=0,
    type_name="HMTSec",
    orient=0
