Model.hm_getentityname#
- Model.hm_getentityname(entity_type_id, style=0)#
Returns the fully qualified HyperMesh entity name for the specified
entity_type_id. Each entity type in HyperMesh is assigned a unique ID. This ID is converted to the entity type name using this function.If
entity_type_idis not valid, undefined will be returned.This is the inverse of the
Model.hm_getentitytype()function.- Parameters:
entity_type_id (unsigned int) – The unique entity type ID.
style (unsigned int) – The type of name style. Valid values are 0-7.
- Returns:
hwReturnStatus- Status objectHmQueryResult- Result object containing the output values:entityName (str)
Examples#
Get the name of entity type 1 ( nodes )#import hm import hm.entities as ent model = hm.Model() _, result = model.hm_getentityname(entity_type_id=1) print("entityName", result.entityName)
Get the name of entity type 11 ( properties )#import hm import hm.entities as ent model = hm.Model() _, result = model.hm_getentityname(entity_type_id=11) print("entityName", result.entityName)
Get the name of entity type 8 ( load collectors )#import hm import hm.entities as ent model = hm.Model() _, result = model.hm_getentityname(entity_type_id=8, style=6) print("entityName", result.entityName)
